Casserole Trivets
SSW60Use longer blanks to make larger trivets
By Ron Forsyth
When I was having dinner with a neighbor one night, she served a casserole hot from the oven. To protect the table, she positioned two trivets side by side, which inspired me to make trivets large enough to hold a casserole dish. However, without gluing up blanks, it’s difficult to find wood more than 7 3/4″ (197mm) wide. I decided to design patterns that use longer, rather than wider, wood to accommodate casserole dishes.
Making the Trivets
Cover the wood with blue painter’s tape and attach the pattern to the tape. Drill blade-entry holes and cut the inside frets. I cut the perimeter last, especially if the design has a round outline (see Tip). Use a 1/4″ (6mm)-radius roundover bit in a router or laminate trimmer (a smaller, less expensive version of a router) to round the outside edges of the trivet. Sand the trivet and remove the dust. Finally, dip the trivet in an oil finish, such as salad bowl finish, to seal the wood and accentuate the grain.
If you struggle to scan and print large patterns from the pattern pullout of Scroll Saw Woodworking & Crafts Fall 2015 (Issue 60), the patterns attached have been tiled so you can download and print on standard 8-1/2” by 11 paper.
casserole_trivets_download
Download now!
Whether you’re just getting started in the world of scrolling or have been making dust for decades, Scroll Saw Woodworking & Crafts is the must-have manual designed to help you make the most of your scrolling time. Each issue is packed with projects, instructions, photos, tool reviews, tips, and techniques. Expert guidance from the world’s most talented artists and scrolling instructors helps you to complete more projects and hone your skills. It’s easy to order and there’s absolutely NO cost or obligation! Get your FREE copy today!
