Add a bit of dimension to your Koala fretwork portrait with this leafy fretwork frame. To use the frame, attach the pattern to the blank. cut the frets, and paint or stain it an appropriate color. Carefully glue it to the front of the Koala fretwork portrait, and add some sort of black backing. Because of the thickness of the material, you may need to increase the depth of the rabbet in the frame.
Download The Koala Fretwork Pattern Here
