Combine fretwork snowflakes with wooden bulbs to make elegant ornaments
By Sue Mey
Cut by Leldon Maxcy
[button link=”https://dev.scrollsawer.com/wp-content/uploads/2019/12/WEB-ShortCuts-Snowflake-Ornaments-Patterns.pdf” bg_color=”#ff0000″] Download the Pattern[/button]
Compound-cut ornaments look great but are quick and easy to make. In fact, you can complete each one with just a few cuts. The snowflake accents are equally easy to cut. You could also fill the recessed space with a photo or initial to personalize the ornament.
Making the Ornaments
Cut the wood to size. Fold a pattern along the dotted line, apply adhesive to the back, align the fold with the corner of a blank, and press the pattern into place. Drill the hanging hole (if marked). Drill the blade entry holes for the inside cuts, and cut the inside frets on both sides. Cut the perimeter on one side, making a single continuous cut around the ornament. Secure the cutoff pieces with clear tape and cut the other profile. Remove the waste, and sand away any rough spots.
Adding the Inlay
Stack together several pieces of 1/4″ (6mm)-thick wood. I suggest using a color that contrasts with the ornaments. Drill blade-entry holes and cut the snowflake inlays. Separate the stacks and sand the snowflakes smooth. Use a 1 1/4″ (32mm)-diameter Forstner bit to drill a 3/8″ (1cm)-deep hole in each bulb ornament for the inlay. Smooth the edge of the drilled hole and glue the inlay in place using cyanoacrylate (CA) glue. Apply a clear spray finish.
Materials and Tools
Materials
- Hardwood, 2″ (5.1cm) square: bulbs, assorted lengths
- Contrasting hardwood, 1/4″ (6mm) thick: snowflakes, scraps at least 1 1/4″ (3.2cm) square
- Adhesive: spray or glue stick
- Tape: clear
- Sandpaper
- Glue: cyanoacrylate (CA)
- Finish: clear spray
- Scroll saw with blade: #9 skip-tooth
- Drill with bits: assorted small, Forstner 1 1/4″ (32mm)
- The author used these products for the project. Substitute your choice of brands, tools, and materials as desired.
Sue Mey lives in Pretoria, South Africa. To see more of her work, including a wide variety of patterns and pattern-making tutorials available for purchase, visit scrollsawartist.com. She can be contacted at suem@storage.co.za. Her pattern book, Lighted Scroll Saw Projects, is available from schifferbooks.com and other outlets.
• Get the current issue! [button link=”https://foxchapelpublishing.com/scroll-saw-woodworking-crafts-issue-77-winter-2019.html” bg_color=”#ff0000″]Purchase the Issue[/button] • For more articles like this, subscribe to Scroll Saw Woodworking & Crafts magazine. • Plus! Get digital mini magazines in your e-mail between printed issues. Subscribe to our free e-newsletter, Short Cuts.
[button link=”https://dev.scrollsawer.com/category/enews-short-cuts/” bg_color=”#ff0000″]Subscribe to Short Cuts[/button] |
