A quick and easy solution to unwanted wood scraps
By Carl Hird-Rutter
My shop is full of scraps, which I find hard to throw out. I thought of a way to remedy this problem with doorstops that can be cut from 3/4″ (19mm) scraps or even 2×4 offcuts. To make sure no small pieces from your doorstop project fall through the hole near the scroll saw blade, create a zero-clearance jig to keep all your wood pieces on the saw table.
Making the DoorstopsPhotocopy and attach the pattern, placing the pattern on the milled edge of the wood to ensure a straight cut. Cut the pattern using a #5 reverse-tooth blade. Drill holes for the eyes. Perform an inside cut on the beak of the owl. Sand and finish, or leave natural. If the doorstop slips on the floor, glue a piece of foam shelf liner to the bottom. |
Materials • Wood scraps: at least 3/4″ (19mm) thick • Sandpaper |
Tools • Scroll saw blades: #5 reverse-tooth • Drill with bit: 1/8″ (3mm)-dia. |
| About the Author |
Carl Hird-Rutter has been scrolling for more than 15 years. Four years ago he suffered from a stroke, which slowed his creative process. With the arrival of his grandson Max, he has a renewed interest in scrolling and hopes to produce many more patterns. |
Purchase our spring issue![button link=”https://foxchapelpublishing.com/products/scroll-saw-woodworking-crafts-issue-94-spring-2024″ bg_color=”#ff0000″]Click for Spring Issue[/button]
For more articles like these, subscribe to Scroll Saw Woodworking & Crafts magazine. [button link=”https://foxchapelpublishing.com/products/scroll-saw-woodworking-crafts-subscription” bg_color=”#ff0000″]Subscribe[/button] Plus! Get mini magazines in your e-mail between printed issues with Short Cuts, our e-mail newsletter. [button link=”https://dev.scrollsawer.com/enews/” bg_color=”#ff0000″]Subscribe to Short Cuts[/button] |
